Pipe Cap 12 173 08-s
Scrubcadet10
Moderator
Staff member
Is this the correct price? the tube is only $8 and the cap and is 17.50? appears to be $17 every where else so i guess it is...
PT you couldn't be more right. It is the convenience tax.
From Kohler that is the price but one my sources has them for under $2 plus shipping. The only difference is Kohler is steel and the alternate is brass.
Even if you insist on steel it is under $7.
Either I don't think oil pressure will the problem.
Scrubcadet10
Moderator
Staff member
thanks. plan on getting rid of the yellow drain this mowing season.
Local Home Depot has f4” pipe nipple and a cap for less than $2.00
