I'm not cleaning any carbs just yet, but in the near future I'll have to clean my Mountfield's carburetor, so I'd better learn how to!
Thanks for the quick reply!
I'll follow that link in a second.
... best to soak all your disassembled parts overnight in a clean pan with carb cleaner for the best results
I must disagree...purchase good quality fuel, keep the can you pump it into capped, keep the mower fuel tank cap on tight, and odds are you will never have to clean a carb. I have never had to clean anything except a float bowl and main jet on any of my equipment.
I agree I have a JD with a Kawasaki engine and it is 25 years old and I have never done anything to it.
Like you say careful fueling and use Stabil while in storage and I will use some carb cleaner in the spring just to make sure I don't have any gum deposits and it will run forever.
There are some great carb cleaning pictures and descriptions at ... Small Engine Equipment Troubleshooting, Repairs and Safety
scroll down till you see your carb on the left... then click the description...
What engine are you carb cleaning? :smile:KennyV
