smalltownguy2
Picked up a 1987 214 from my neighbor last night for $300. Runs good, but he tells me that the variator needs work. I can confirm that upon driving home, I observe that the variator lever does nothing, and when in gear, the mower does not stay at a constant speed. At times it will surge forward. Most times, it slows to a crawl until you bump the clutch pedal, then it will surge forward and drive for a bit.
Over the next couple of days, I'm going to remove the variator assembly and inspect the sheaves, belts, slide, and other parts. I suspect something is dirty/worn/disconnected.
I'll keep you guys posted.
