Pennzoil 2 Stroke Oil
To each his own on 2-stoke oil, really any oil you run through a lawnboy is going to work well given the operating Rpm and HP out put. I have been snowmobiling for over 20 years, since most current snowmobiles have power valves that tend to gum up and cause running issues. Ash less and oils that do not build up carbon is a must. I have used Blue Marble for 10 years in all of my 2 stokes snowmobiles from a 600 to 1000 cc. I do not have to clean the power valves only inspect them. I would think the issue of plugging a muffler with carbon should be greatly reduced using an oil like blue marble.
Amazon.com: Blue Marble 2-Cycle Oil - 1gal. FG0007-GALLON: Automotive
I have been using Pennzoil Full Synthetic OUTBOARD MOTOR oil in my Lawnboy mower, Toro S-200 snowblower, weedwacker, and gas leaf blower for 10+ years with no issues whatsoever. Most outboards are water cooled to about 140 degrees, so oil formulas need less temp to burn off port deposits. I buy it at Menards for about $28 a gallon. Pretty cheap for full synthetic and its 100% biodegradable to boot.
Actually It's been said it before with today's advances in oil technology compared to the 80's almost any 2 stroke oil will work!!
