PB195h42lt poulan
randy merryman
MY poulan won't start unless I jump start it on the solenoid. Ignition switch is new. Once it is running I can get off w/o engaging the parking or disengaging the deck and it stays running. checked the one fuse I could find and replaced it . It's a hydrostat if that matters.
One of the plugs on a safety switch has fallen off or been broken or the switch itself is broken .
Prime candidate will be the brake switch which is under the mower .
To start off the key the power goes through the PTO switch then the brake switch then to the trigger on the solenoid .
The safety switches are ground switches
PTO + Seat
o r
Seat + brake
These are parallel circuits
And what matters more is weather it has a manual or electric PTO .
randy merryman
PTO + Seat
o r
Seat + brake
You were 100% on the problem. had to remove gas tank to find the bad ground. It was a ground wire coming off the brake switch.
Thanks for coming back & closing the thread.
It will help untold other in the future
Glad you got it sorted.
