PB-770T, use treated gas? And cold operation
plpauly
Hello,
A couple questions. Should I treat the oil/gas mix for this blower? What are some recomended products?
Also, In the manual, it says:
Cold Weather Operation:
1. Remove back cushion (A) from frame.
2. Install intake cover (B) on frame over air intake.
3. Install back cushion (A) to frame over intake cover.
Note: Blower performance may be reduced slightly.
What exactly is considered cold weather? 50°, 45°, 35°?
thanks
Hello,
What exactly is considered cold weather? 50ー, 45ー, 35ー?
thanks
Should I treat the oil/gas mix for this blower? The answer to that question is No. Most oils like the Stihl or Echo and others already have stabilizers in there oil so there's no need in doubling up on the stuff and maybe creating other problems. As far as what they consider to be cold is anyone's guess, it should sat something in the manual.
