mrredpants
- May 20, 2014
- 3
Reference to part names comes from this site
One of the fuel line stems broke on the purge base assembly. I ordered a replacement and in the interim got some spray carb cleaner and partially disassembled the carb to clean it up.
I removed the rotor cover assembly. This exposed a center pin. I sprayed cleaner here and cleaned the rotor cover. The issue is that when I replace the rotor cover assembly, pulling the throttle cable does not result in a smooth rotation of rotor(?) Within carb. There's friction and have to pull cable much harder than before I disassembled.
I've inspected it closely and can't find a reason. Does this need to be lubricated at all? Am I missing something?
Thank you very much in advance.
