parts list fh601v bs15
woodworker4421
does any one have parts list for a fh601v bs15 motor?i am looking for a crankshaft?
Here’s a service manual and parts breakdown for your engine. On the parts tree site you’ll need to add your 4 digit spec number to get the correct engine.
The problem is that this is most likely a Kawasaki used on JD; therefore, most sites will not have the exact IPL as JD USA is trying to hide them so you would buy only from them the parts. The following is the PNs for the BS15 spec. Most of these are common with the other FH601V specs.
PN 13031-7023 Crankshaft
PN 11061-7098 Crankcase cover gasket (Oil Sump cover)
PN 92049-7010 Seal-Oil,SD 35X48X8 R (Flywheel Side)
PN 92049-7011 SEAL-OIL SD 35X62X8 L HS (PTO Side)
PN 11004-7006 Head Gasket (2 Each)
PN 11060-7013 Rocker Cover Gasket (2 Each)
Source: Kawasaki Motors
