Part Numbers and Date Code Questions – Please
I have a Craftsman ZTS 6000 with a B&S Engine and I want to order engine parts. Specifically, I need to replace entire Governor Assembly and the Engine Pulley.
Following obtained from Engine
Build Date: 01.09
Model: 445877-0132B1
Serial: 090106YG02532
Platinum Engine Series
724cc 26.0 Gross HP
with XRD.
Below are examples of entries in the B&S parts manual.
211 691019 Spring-Governed Idle
-Used After Code Date 10072200
211 796225 Spring-Governed Idle
-Used Before Code Date 10072300
Question:
How do I determine what my Code Date is?
Any other parts advice would be appreciated.
Thanks
Leaky
Build Date: 01.09
724cc 26.0 Gross HP
with XRD.
Question:
Thanks
Leaky
