Part Needed - Craftsman DGT 6000 (Model 917.276120)
mwolf
I need part #175805 (plate asm. susp. front), but can't locate new or used online. Any help pointing in the direction where I can locate one would be greatly appreciated.
It supersedes to 532175805 which is no longer available. Best bet is search your local dealers to see if anyone has one in their boneyard. Take a picture with you so they don’t have to look it up.
tom3
Is that something that could be welded up or have a rod made for it? About anything like thatcan be fixed.
Depends what is wrong with it. It’s the bracket which connects the deck to the frame.
HughDaHand
If you can't find that part you could probably use the old style front hangers. 2x part number 127218, they are readily available.
