If you look at your spark plugs, they're probably black. It wouldn't hurt to change the oil, too.
cpurvis Lawn Addict Joined Aug 25, 2015 Threads 21 Messages 2,256 Apr 26, 2018 / Over choked??? #11 If you look at your spark plugs, they're probably black. It wouldn't hurt to change the oil, too.
L Luffydog Well-Known Member Joined Jan 31, 2018 Threads 6 Messages 566 Apr 26, 2018 / Over choked??? #12 Need the model number should be on the valve cover or the engine shroud. Example 402777-0123-e1. Should look like that. Find those numbers
C Chugbug Active Member Joined Mar 28, 2015 Threads 13 Messages 55 Apr 26, 2018 / Over choked??? #13 The only model number was in a previous post that was the only model can find. Changed oil yesterday.
