Oregon Blades pained
rigoletto
People,
Got 2 new Oregon blades for my MTD mower. They are pained black with high gloss paint. And the edge doesnt seem sharp when I run my finger across it. Is this normal?
Thanks.
Mower King
Yes, that is normal.....most all new blades are not "razor sharp" at all!
People,
Thanks.
Oregon sharpening standard is called 30-30 Which means sharpened at a 30 degree angle with a 30 thousands blunt edge. It is not recommended to put a knife edge on a blade because that edge wears down very quickly and will be at 30 thousands within a short period of time therefore no reason to remove more metal then requires.
Also when the paint wears off the leading they will be sharper. The paint also provides a safety factor for those handling new blades so they don't get cut easily.
rigoletto
So good to know, people. I cant wait to cut grass.
(I spelled paint wrong!!)
Anyway, another post coming in equipment.
Thanks!
