Jharbin
- Aug 2, 2021
- 3
Ok...so I think I reached the last page of the Internet with this one and can't figure this out. Have a B&S 422437 type 1281 01 that was running and just died. Thinking it was carb related, I cleaned carb. No luck. Checked spark and it had weak spark. Checked fuel pump....had plenty of pressure, but I did clean the pump too. Ended up being coil after all. Replaced coil and put back together. Started right up, but was screaming. Multiple write ups suggest governor adjustment, but I've adjusted both ways and no luck. Throttle seems do do very little (if anything). I can idle it down by turning in the fuel mixture screw, but still no throttle response. Any ideas? I'm stumped.
Trying to attach pics, but all were too large.
