- Sep 24, 2017
- Threads
- 250
- 6,441
I've been tinkering with this engine for a few months. Mower has no deck so it's not very important
42A707-2653-E1
Whenever i rev it up high, and the bring it back down to idle, it always tries to or does die, i can bump the throttle up just a hair and it will recover some... i replaced the chinese carb i had on it with a good running OEM used carb... still same issue. Rev it up high, then bring it back down to idle it wants to die.carb is the non adjustable one except for idle speed.
All intake and carb gaskets are new, I've verified that it is running on both cylinders. I'm also wondering, with the engine being 20 years old or so, could it be a valve or valve timing issue?
Spark is good blue on both cylinders, when it idles good it sounds great, and high rpm sounds great...
I'm just wondering if maybe i have the idle set too low perhaps? To my ear it sounds about right... My tachometer stopped working for some reason, need to go buy a new one.
Thanks in advance.
42A707-2653-E1
Thanks in advance.
