Morning all. First post for me. I have a B/S 10L 9020577 4.5 hp mower engine. Have been trying to replace engine stop bar with just a kill switch. In tests the line from coil to switch to ground back at the mower engine all checks fine, or like it should. But as soon as I place grounding clip back onto the coil my test of the hook up to switch for on and off with an Ohms Meter shows that the circut is open and will not ground out coil to stop the engine. I have been playing with this for several days, but now I am at a loss. Hoping for a clue so I can turn this mower off after use. Thanks Jim
