Only runs on low
Zjmast
Hey, I have a briggs and stratton model 252707 with 11hp. I just cleaned out the carb, the tank, and put a new fuel filter. My problem is that I can only get it to start on low idle. The engin will not run on choke and if it does it spiders out real quick, and when given little gas, it dies. Can someone tell me what going on? Thank you!
It is starving for fuel. Did you remove the main jet and emulsion tube to clean them?
