Craftsman Garage
- May 2, 2021
- 38
- 497
is your spark plug working?
fuel lines too maybe?
I measured the length of both pickup tubes to make sure they were not sitting flat on the bottom of the tank, and added an additional gasket to give a few thousands more.Yes, spark is good
I changed the mag thinking that although there was spark, maybe it was too weak to fire it
Fuel lines are part of the base of the carb - both have fine screens on the bottom (both clean)
Both the old carb that I cleaned, then rebuilt, and the new carb, which is not an OEM, act the same way
So what is your procedure for adjusting it, because I think it IS in adjustment, but always willing to learn something newhmmmm, i think then your carb could be out of adjustment
the setting for the mixture screw is turn in until snug, and then back out 1 and a 1/4 to 1 and a 1/2
That’s where I am at - I have gone leaner, and I have gone richer, same frustrationthe setting for the mixture screw is turn in until snug, and then back out 1 and a 1/4 to 1 and a 1/2
