Tommyb2401 Forum Newbie Joined Sep 11, 2021 Messages 9 Sep 13, 2021 #1 Engin model 204412 which is on a 5500 generator will only attempt to start when gas is poured in the the carburetor. I have cleaned the carb several times and still no luck.
dougand3 Well-Known Member Joined Mar 10, 2012 Messages 461 Sep 13, 2021 #2 Full disassembly cleaning? Wire the orifices? Needle and float work properly?
Scrubcadet10 Lawn Pro Staff member Community Leader Joined Sep 24, 2017 Messages 6,975 Location Conroe Sep 13, 2021 #3 this manual should cover it. Google Drive: Sign-in Access Google Drive with a Google account (for personal use) or Google Workspace account (for business use). drive.google.com
S slomo Lawn Pro Community Leader Joined Jul 14, 2019 Messages 7,217 Sep 14, 2021 #4 How often is the genny ran? Most just sit around all day in the blazing heat varnishing up the fuel. How did you clean the carb? Spray some carb cleaner on the outside only? Put it in the wife's dishwasher or ultrasonic cleaner? Use any round carbide files on those brass jets?
Tommyb2401 Forum Newbie Joined Sep 11, 2021 Messages 9 Sep 26, 2021 #5 Thanks y’all figured it out the push rod was not on the intake valve
