One thing or Another
ARMADA175
LawnWorld is a real nice site I wish I could find a automobile repair site this good>
primerbulb120
Pulleys will have to be changed if you want it to go slower. Or you could put on a set of worn out drive wheels with all the tread gone to reduce traction.
Catherine
LawnWorld Support
Staff member
:welcome:
I'm going to move this thread over to our Troy-Bilt section. :smile:
zman111666
Any chance the engine speed is set too high? Shouldn't be going faster than 2800-3000 RPM.
EngineMan
Hasn't it got a cable adjustment, back it off a few turns...!
ARMADA175
Yes throttle RPM has been moved to Maxim, motor handles with no problem Do not know what the RPM reading is.
ARMADA175
Where is Troy-Bilt section?
Thank you
primerbulb120
No cable adjustment on these. Unlike some models they don't use the belt to engage the drive, the engagement mechanism is inside the transmission.
ARMADA175
Great answer I will leave subject alone.
Thanks
Kevin
