ptownnative
- Jul 30, 2013
- 1
- 8
Okay, so I've attached a video showing the play in the axle... In the meantime, I discovered what I believe to be at least part of the problem. In the two pictures I've attached, labeled "good side" and "bad side", you will notice that the bad side isn't quite flush; it seems that something did in fact get bent, probably when my neighbor was rough-housing the mower into the trunk of his car. Something clearly needs to get bent back--but I'm not sure what, and how. Ideas? Thanks again!
Oh, and I've put the bad wheel back on, so as not to ruin the good one. I've gotten along so far with one-wheel drive, I can probably make it through the rest of the summer.
Tony
Tony
