Onan CYL2 heats up much quicker
skippymud
Hello All
1988 Onan P220G Opposed Twin. S/N unknown. MFR date is stamped on the flyball cover. Electronic ignition. Awesome beast of an engine
I got this engine as a POS on Craigslist and rebuilt it from ground-up
End result of my build is that CYL 2 runs much hotter than CYL 1 by anywhere from 70F to 100F. The temp difference is more extreme just after start-up and for the next 6 minutes or so at idle. Beyond that timeline, the levels L-R level out a bit but still uneven by 40-50F, all of which is unnerving for me
I bought oversized rings for CYL 2 from OnanParts in hopes that I could close the ring gap to 0.003-0.008in per spec but that didn't work. Gap remains at about 0.013. So I put it back together and hoped for the best. The heat ratio on CYL2 vs CYL1 remains a mystery
What could be the causes of CYL 2 heating up?
How are you checking the temp? What is being used?
They are not going to be 100% the same temp. Especially when both cyls have different compression and blowby for example. Valves might not be sealing 100% and many other factors. Sounds as cyl 2 is getting less fuel than 1. Leaner is meaner was the old wordage. Intake ports are not identical.
skippymud
Good point. I will check that the valves are seating properly
There is not one engine out there that multiple cyls run at the same temp. Go scan a V-8 and report back. And those mostly are injected supposed to be spraying the same volume of fuel and so on. Casting thicknesses and many more.......
skippymud
I hear ya, slomo, and have considered the countless variables. Though an 80-100F variation seemed a bit excessive to me on a 782cc engine. The fact that you are saying this is normal, I will sleep much better LOL! Thanks again! - Ken
Don't think it's normal but we need some word to talk about it. Some carbs have 2 different main jet sizes. Like the ol' Nikki Six carbs I think that fit twin engines. You might have Chinese plugs or one not firing 100%. Many many variables.
Does your carb have two different main jet sizes?
Again the same with V-8's. One fuel pump and 8 injectors all rated the same fuel volume. Every cyl will have a different air/fuel ratio.
skippymud
Hi slomo. I believe it has just one main jet. See pics. Plugs are Champion RS14YC
