theoldwizard1
- Sep 9, 2012
- 13
- 36
I'm trying to help out a friend. He has an old Toro T2500 generator. The carb is in very bad condition but Toro says all of the parts are discontinued. I don't know what type of engine it is, except that it is a 4 stroke. The carb looks like a typical Walbro with the main jet through the bottom of the bowl. No primer.
What distinguishing marks should I look for on the carb to determine if it is a Walbro and what model ? A new bowl, bowl O-ring, O-ring seal/gasket, needle and float and I think it will be good to go !
