Have an old JD 110, 1973 model with a K241, which I have been tinkering on for a couple years. Finally got it up and running, began chopping leaves. Ran well for about 2 hours then it stopped dead, seems like fuel starvation. If you wait a few minutes it will restart but only very briefly, not even long enough to suck a float bowl dry. Plenty of good gas, fuel line unobstructed, when you spin the starter with the fuel line disconnected at the carb you can see fuel squirting. Removing the float bowl finds it full of gas, the float bobs freely up and down, and it is clean as a whistle in there. Choke and throttle cables are connected and working well. Sprayed WD40 through the holes for the main and idle circuits, seems no obstruction there either. Put the bowl back on same brief start up. If the main was plugged it would idle and if the idle was plugged it would run with throttle open. It is not smoking and the plug is clean. Any helpful thoughts?
