crazy charlie
- Nov 18, 2018
- 98
Gonna check that thanks!!You can call it a clutch, but if you look closely you will see that it nothing more than a CV drive where the more tension you put on the handle, the faster the unit will drive and the blade will engage with very little tension on the handle. Take a look at the manual I posted earlier to see how this works. If it seems to be going slower, the most common cause would be a worn belt or bad idler pulley.
