I have a Toro super recycler that is from 1999-ish. It’s a Toro model # 20040 SR-210S serial # 9902466.. I have looked up the mower on Toro’s site and it is not identified with a Briggs model # and is referred to as a model GTS200. That said it appears to have been made by Briggs and is an overhead valve 6.5 hp engine.
I have two issues I need help with. 1. The engine seems to run at too high of a RPM. There are no adjustment screws on the carb. The engine has a primer for starting not a choke model of carb. Not sure what I should try to do to make it run slower. I have had the carb off and cleaned it. I did notice that the throttle butterfly seems loose almost to the point of being sloppy. Not sure is a worn throttle shaft could cause the runaway speed issue.
2. The mower starts fairly easily when cold, but a warm/hot restart is very difficult. It seems to give a little bit of a backfire sort of pop when trying to warm restart. I adjusted the valve lash on both the intake and the exhaust to .005 and it doesn’t seem to have solved the problem. It has a new spark plug and aside from the hot restart issue, it seems to run great, doesn’t smoke or miss when running.
Any and all comments and insights are greatly appreciated
