Engine oil warning light
BigC
Need some help. I have a walker with a 20hp kohler commander gas burner engine. I just pulled the engine and installed a new starter. After I put it all back together and started it up, the oil light and alarm came on. oil level is perfect, not overheating, sounds good running. I looked a the oil sensor connection on top of engine under air filter. Looks ok. It has to be an connection problem? Does anybody have an idea.
Not familiar with that warning light on that engine. As a rule they work off a ground or negative power. The very first thing to look for would be a pinched wire.
