Lbutler225
- Apr 13, 2017
- 4
- 19
Ferris IS700Z....Briggs and Stratton 28HP Twin.....524 hours....4 years oil....I had a broken push rod (aluminum) in the oil sump ...a mechanic removed pulled the engine and removed it....when i got the mover back it was using oil and turning it black...no smoke and no leaks !!!.:confused2:..Scrathing our heads ...the new plugs were white on the end... looked like a white fuzzy mushroom.. after just a few hours...I noticed the oil cooler wasn't snug on the engine ...missing 2 of the 4 screws...Just sounds like the oil is getting hot.....We will see after running it today....Im still not sure how oil is forced through the oil filter/cooling system...nothing on YouTube that spells it out in a simple manner.....
