Hello peeps.Question for ya.I've got a MTD rider with a 12.5 Briggs & Stratton that is pumping oil into my carb.Replaced the head gasket but the oil is still pumping out of a small hole located inside the breather box.The hole is about the diameter of a toothpick on the bottom right.I turn the engine by hand and it pumps out a pretty good stream.Not to mention there is also gas in this oil.Something a basic guy could fix or should I junk it out.Any help would be greatly appreciated.Thanks,take care and be safe out there.
