Did it smoke when it was runing
Ean Well-Known Member Joined Feb 26, 2014 Threads 39 Messages 142 Mar 30, 2014 / Oil on plug #11 Did it smoke when it was runing
wjjones , Joined May 29, 2011 Threads 50 Messages 1,456 Mar 30, 2014 / Oil on plug #12 If you pulled the head cap off you will have to have a new gasket the old one will never re-seal properly.
C coosmower Forum Newbie Joined Mar 30, 2014 Threads 1 Messages 5 Mar 30, 2014 / Oil on plug #13 wjjones said: If you pulled the head cap off you will have to have a new gasket the old one will never re-seal properly. Click to expand... Could be a reason is was overheating then? Yes it blew out a bunch of smoke when it started then not much after a few minutes of running.
wjjones , Joined May 29, 2011 Threads 50 Messages 1,456 Mar 31, 2014 / Oil on plug #14 coosmower said: Could be a reason is was overheating then? Yes it blew out a bunch of smoke when it started then not much after a few minutes of running. Click to expand... Yep replace it with a new one, and let us know how it turns out. I repaired a John deere rider that was doing the same thing, and it was a bad head cap gasket.
