Hello. I have a question. Will a bad oil sensor disable the key start or only ground the coils?
C cwbyjms Forum Newbie Joined Apr 24, 2017 Threads 1 Messages 2 Apr 24, 2017 / oil level sensor #1 Hello. I have a question. Will a bad oil sensor disable the key start or only ground the coils?
I ILENGINE Lawn Royalty Joined May 6, 2010 Threads 43 Messages 10,734 Apr 24, 2017 / oil level sensor #2 All of the oil switches I have seen will either prevent fire to the plugs, or cause a short 5-10 run before shutting down the engine.
C cwbyjms Forum Newbie Joined Apr 24, 2017 Threads 1 Messages 2 Apr 25, 2017 / oil level sensor #3 Thank you. The wire that connects to B prong on switch lacks 12 volts and am trouble shooting. Thanks again.
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 65 Messages 24,995 Apr 25, 2017 / oil level sensor #4 The oil level safety switch is a grounding switch that grounds out the coils when the oil level is too low.
