oil leak
joeyb
I have a ferris 3 wheeler that has a oil leak coming from the bottom of the motor it looks like.anyone have any ideas not that bad of a leak just don't want it there?
reynoldston
That has to be a Ferris PRO 60. Through the years I know of they have different brand engines in them. What engine and model engine do you have in yours? Also how old is your Ferris seeing they have changed the chassis and running gear on them also.
joeyb
It is a pro 60 with a briggs 26hp.I think it could be some loosebolts on the motor but it is tough to tighten by yourself
ventureman
Most likely your oil seal is leaking. I would definitely investigate further before using the machine...
