oil leak
Jerry Fanning
I have a 1995 john deere lx277 with a kaw. engine, how hard is it to put oil pan gasket on it . would like to hear back.........
reynoldston
What a surprise, didn't know Kawasaki give any problems like oil leaks. Not that bad of a job. First thing is to remove the engine from the chassis and work on a bench. I would also install a new seal in the crankcase cover once you have it off to install the gasket.
