Oil leak on brand new Titan Max
Gord Baker
I forget the problem now.... Oh Ya. Wipe it down as much as possible and leave it running to try and determine where the oil is coming from. Gasket or Seal. Some cardboard underneath the suspect area may help after it is turned off.
Cornfield
The dealer called yesterday. It has a leaky valve cover gasket. Is that common on a new Kohler 26 hp 7000 series engine?
If there is any oil/grease residue on the mating surfaces when they use then RTV sealants they will not adhere properly and quickly start leaking.
