Tired-n-dusty
- May 12, 2018
- 1
- 4
I have a Cub Cadet ZTR with a Kohler Command 23 hp engine. I recently did my annual oil change + filter. Everything was fine for a short while after doing this. A couple of days ago my son went to cut the grass and stopped because oil was profusely leaking out around the oil filter area. The first thought was that the filter was not screwed on tight enough. We re-tightened, and it still was leaking whenever it was running.
My next thought was that the gasket from the previous filter must have been left on the oil filter face plate or the gasket on the new filter has dislodged. I drained the oil and took the filter off. Everything was as it was supposed to be. I even went ahead and placed a new filter on it. As soon as it started up I could see oil quickly dripping off the bottom of the oil filter face plate.
As best as I can tell, the leak is coming from behind the oil filter face plate. The manual suggested a blocked breather line could overpressure the crankcase and cause a leak. I checked and I can easily blow through the line.
The oil filter face plate seems integrally attached to the block. Is there some way the screw on nipple is leaking from behind the face plate?
Other suggestions?
Thanks
Tired-n-dusty
Other suggestions?
Thanks
Tired-n-dusty
