Oil Leak From Drain Valve
RT9191
Thanks for all the replies. I went ahead and bought a few o-rings and I'm going to change it out, since I need to change oil soon, anyway. I tried to tighten the adapter but it's as snug as I can get it.
I'll report back with the results.
7394
(y) There a Kawasaki conversion kit to replace the poly-plastic drain to a 18" rubber drain hose, I might do that end of next season..
You can see then on Ebay or @ Kawasaki parts online, but not cheap.
