Oil for new cub cadet XT1 LT46
Roadcadet
My mower cub cadet XT1 LT46 will exhaust some blue smoke and then stop. It happens when first started? Told that was normal? Told to use synthetic oil 20w50 outdoor power equipment ? Any commets. Thanks, Kim
Most likely it is oil seeping past the rings while setting overnight or longer. And then burns off on first startup. Shouldn't happen but is quite normal for a lot of engines.
Auto Doc's
My first question would be is the oil level hi? If so, does it smell like it has gas in the oil? Fuel will overthin the oil, raise the level and cause smoking.
I use Pennzoil 10W 30 year-round. Synthetic is a waste of money and not recommended on a new small engine. Synthetic can actually delay piston ring break-in.
A puff of smoke on a new engine at startup is not uncommon but should go away after the first 25 hours of break-in run time.
If it continues, there is a problem with the valve guides or the piston rings.
20W 50 is used in larger automotive engines and too thick for small engine.
Auto Doc's
Old outdated information. This saying is not true and may of never been true. Most of the small engine manufacturers are not even offering dino oil as an option in their own branded oil. So synthetic oil in a new engine is fine.
Agree. The ol' don't use synthetic oil in a new engine is garbage. All oils are formulated to be "roughly" the same for specific vehicles. Also in the USA, printing synthetic on the bottle doesn't mean it's 100% synthetic. Might be ONE item in the add pack that is synthetic and they call the entire brew synthetic. Not true in Europe. Over there if the bottle says synthetic, it is true. Redline and Motul are synthetics. Anything that is not a group 4 or 5 is dino juice.
True. Dino oil with synthetic additives can be called synthetic oil.
