rstevenson
- Jun 9, 2015
- 1
- 1
own a Husqevarna rider, 23HP,Briggs engine. Looking for a oil filter to replace the B&S part #492932. Too expensive!
LOL got that right... any forum that deals w/ IC engines.rs, The topic hits nerves in the forum. The pros generally stick by factory issue. I use any I can find like Wix. Fram, WalMart's finest. The key is to do a little checking on thread compatibility and clearance of deeper cans. Armor suit on.
PS. Although e.g., Briggs hints at "cooler" running with their filters I have not seen any proof.
Never lost an engine due to a bad filter, ever. Walmart brand, though no longer made under the name Super Tech, was made by Champion Labs. They always ranked in the top 2-3 filters in tests conducted by independent labs. Briggs and Stratton, like many others, bid their filters out annually. I use K&N in all my vehicles for the sole reason of the welded on 1" hex bung.
To this homeowner it is a shock to see Sears price a Briggs Intek oil filter @ $12. I believe pros should enjoy a markup to make a living. In the market anything over 10% is good stuff. But hold the bubble packed Briggs in your hand @ $12 and payday loans come to mind. Even if the Briggs is good, is it worth 100% more , or more? As noted it would be if it could be shown to cool the AC engine even 10% better, but apparently it can't just like synthetic oil cannot COOL better. Printers come to mind with their loss leader machines and their insanely priced, sole sourced ink. Except there are choices for the filter buyer. Again I say put a couple gauges on all AC rigs with a buzzer, red light warning and a rubber hammer strike to the forehead to warn of overheat/oil loss- for about the price of 10 Briggs filters. Then enjoy the improved reliability and reputation.
