Oil Filter Wrench Size
RustyBoy
Hey guys,
I have a Gravely mower that takes oil filter 49065 but can't find the correct fit wrench. I count 14 flutes and I measure either 74 or 75mm I think width. Does anyone know that uses this filter number????
RustyBoy
Forgot to mention that the part number is for the Kawasaki engine - the part number is printed on the filter: 49065.
sgkent
take the filter with you to your local flaps and match up a wrench if you want to use that style wrench.
Either you need to give us the complete filter pn or the engine model and spec numbers. There is the last four digits from the pn given.
But I am thinking it is the 49065-0721 (7007) filter which takes a 76mm/14 flute.
Gym123
I use this type- I have two sizes. If you only want to buy one for all sizes, the yellow one works.
clubairth
I use the 3 jaw version shown above. It works real well on those tight filters that just won't turn.
clubairth
I ONLY install oil filters by hand!
Snug then another 1/2-3/4 turns. I have had my fill of idiots that tighten the filters so tight I have to deform the metal can to get them off. Oil filters just don't need all that force!
Then you haven't the problem that Briggs is having with them loosening after hand tightening. I personally have seen them to come loose here with 1 full turn which is why Briggs spec'd tightening to 100 in lbs.
Most stuck filters is where the seal wasn't lubed prior to installation.
