Heads up on this.
Guys I have been seeing this issue a lot lately. Oil filters that tighten to one turn per the filter's instructions are becoming loose. Briggs has recommended that these filters are to be tighten to 100 in-lbs or to 8 ft-lbs using a filter fluke wrench.
It is probably the type of rubber used that is causing this problem.
