Oil extractor woes
PTmowerMech
Well, I'm in the market for another oil extractor. My plastic POS finally bit the dust.
Someone on this site posted they used a pump, that puts the oil into a fire extinguisher. I'd like to see that set up. Especially the pump you used.
I'm also wanting to look at the prices on a two way system. Something that I won't have to use my back too much, having to pour out the contents, but using air to push it out.
I'd like for it to be either electrical or pneumatic, so i don't have to stand there and pumping and waiting.
Hammermechanicman
I use the HF air extractor. Only bad thing is picking it up to dump it into my 20gal barrel.
PTmowerMech
The truck repair shop across the street said I can dump my used oil in their containers, because they burn it in the winter for heat. But their containers are hard to get to and higher than a barrel.
But there's access to air right there.
If HF's was a two way, I'd buy it in a heartbeat.
