If I were you I would get a service/shop manual for your engine. I don't want to insult you but if you are going to "rebuild" an engine you don't reuse rings. A engine service/shop manual will give you a step by step run down to correctly rebuild an engine. It will have all the info you will need. Did you reuse the head gasket? Did you torque the head bolts in the correct order? I see others are helping you also now.
You are right, I should not have used the old rings. I have a new head gasket and sump gasket. Bolts were torqued in correct order and to spces (I do have these specifications) I'm going back and replace the rings with new ones and do a complete check out. Really appreciate all the help. I have an email in to B&S engineer for compression on engine, if he answers back.
