Every head I've pulled was/has been warped.
Yes your head AND block area where the head sits needs LAPPED. Lapped meaning flat and clean.
Yes you need a NEW head gasket.
Wouldn't hurt to spray some high tack sealant spray ON the head gasket both sides.
Wouldn't hurt to chase the thread holes with a tap while you are there.
Nice to clean the head bolt threads with a die.
Wouldn't hurt cleaning the cooling fins ALL AROUND the cylinder/s. If yours has that tin that directs cooling air around the cylinder/s, needs to come off and clean under and all around it.
Nice to spray the bolt threads with brake cleaner, shop air and SAFETY GLASSES. Keep the threads dry as in NO oil on the threads. Oiling the threads lowers required torque.
As others mentioned, proper torque is good. Mow a couple times and recheck torque.
