mattfinley
Hello all, I need to tap the collective knowledge of the forum to see if I can figure out what is going on with a 98 SilverPro 6.5 hp self propelled 10323..
I just bought it a week or so ago at a pawn shop because I have others and thought for $10 it would make a good parts mower..
So i work on it a bit and figure out the CD ignition is bad and replace it....Bam, runs like a top after cleaning and degreasing..
So here is where it gets squirrely...I decide to mow my grass with it for the first time today and mow for about 15 minutes and everything is going great. Then I hear a slight ringing sound..barely noticeable.. Then the ringing starts to sound like two metal parts just barely scraping...then about ten seconds later the motor starts bogging down like it is in a strain and about to stop so I release the deadman switch and kill it.
A decent amount of smoke coming from the muffler like oil being burned.
So I let it sit for a few minutes and the only thing I can think of is that something got hot and metal expanded and caused the almost grind to a halt...
Prime it twice, starts right up normally....let it run for about 3 minutes....ringing, then pinging, then bind and starts slowing down to stop as if in a bind again..
It has to be something getting hot and expanding, but I can't for the life of me figure out what it would be and why it would take 15 minutes for it to get hot enough to start rubbing and seizing up...
Anybody ever run into something similar or have any ideas?
thanks much
Matt
thanks much
Matt
