- Sep 7, 2024
- 3,489
A weak magnet issue is very uncommon. Old Tecumseh engines had a lot of problems like that, but that has been many years ago.
I have not run into any HF motors with a failed flywheel magnet.
If it will hold/grab a 10" steel adjustable wrench I would say the magnet is not the issue.
Could be you have a poor-quality aftermarket coil.
I have had good luck with coils off of eBay (so far).
Just for curiosity, flip the coil over where it mounts and set the air gap and try it that way. I've seen some strange things happen with aftermarket parts.
I don't recall reading if you had checked the flywheel key to make sure it is not partially sheared.
