o turn is a 0
rachadwell
I have a Craftsman EZT 40 with a Kohler 15.5 hp Mod# 102.273920 Ser# 012000002429 year unknown that I am having a wiring problem with, it seems that something is killing the spark so it will not start. I have looked for wiring diagrams but only find hard to read blurry diagrams with no wire colors, if anyone knows of any good diagrams Please let me know. Thanks, I also unhooked the kill wire and engine starts wright up.
It probably the start relay that is not working.
rachadwell
Thanks Star Tech for your reply , I did see this diagram while I was searching for info but not as clear I will study it and add my colors to it and see if it will work.
It much better than some I get from MTD. Or like JD wiring I did a couple where the wire colors were not the same just the numbers. But I use work with one hundred white wire with numbers only.
