B beerslayer12 Member Joined May 26, 2021 Messages 11 May 26, 2021 #11 i have seen some crazy things fuel related to bad fuel cap vent ?
Scrubcadet10 Lawn Pro Staff member Community Leader Joined Sep 24, 2017 Messages 6,975 Location Conroe May 26, 2021 #12 StarTech said: I even seen a few with negative clearances.. Yes I said negative clearance; otherwords, the valves were being held slightly open even when they should fully closed. Click to expand... So what size feeler gauge did you use to determine what the negative clearance was?
