Not pulling vacuum?
beerslayer12
i have seen some crazy things fuel related to bad fuel cap vent ?
Scrubcadet10
Moderator
Staff member
I even seen a few with negative clearances.. Yes I said negative clearance; otherwords, the valves were being held slightly open even when they should fully closed.
So what size feeler gauge did you use to determine what the negative clearance was?
