Sheridan1
- Jun 25, 2020
- Threads
- 1
- 3
I have a 17 HP Kohler engine on an older Sears Craftsman mower. I was have an issue with the engine running and drawing the fuel filter dry and then not taking fuel like a stuck float. I checked and cleaned the carb and eventually replaced the carb. Now, it still does the same thing, i've replaced the fuel line with new filter and an in line shut off since I saw that one fix could possibly be the little plunger which is on the bottom of the bowl. The "fix" was to cut it off which still did not fix the problem. Fuel flow is good right up to the carb intake. When removed the carb is clear and the float operates properly.
Any ideas on what's causing this?
