conductorjc
- May 21, 2013
- 1
- 1
I have a husqvarna riding mower .The left side blade is cutting better than the right.I,ve sharpend the blades,the blades measure the same on flat surface,and tire pressure is equal and the blades dont seem to be bent.ive swapped the blades and still cuts good on left side.could it be the belt is stretched and nut turning right side as strong as left .need help !:confused2:
