Martin240
- Oct 26, 2022
- 8
Wow you’re good StarTech! That’s the exact schematic from my M2560! I can’t tell that anything is miss wired or isn’t factory, it all looks OEM. I’ll try to play around w it & see if I can switch some things up & get it going. At least I have power up top now. Any advice would be helpful. Thanks again!Okay I think I found the correct diagram for the Woods. I think you got a M2560 unit.
Something is miss wired at the Ignition switch or someone has a jumper in the wrong place or a wrong ignition switch is installed.
